Re-Lacquer after buffing ? http://www-.luthiersforum.com/forum/viewtopic.php?f=10128&t=31415 |
Author: | WudWerkr [ Tue Mar 08, 2011 10:40 am ] |
Post subject: | Re-Lacquer after buffing ? |
I have been buffing out a finish and using buffing compound and have buffed through at one spot . ![]() ![]() This is first time ive had to do this , dont wanna mess it up further . Also , On my mandos , I have been using about a pint of laq. , how much do you spray , am I being to "thrifty" with the laq. ? Is this why I Buffed through, not enough coats ? Please chime in with your suggestions . |
Author: | Jim Watts [ Tue Mar 08, 2011 2:54 pm ] |
Post subject: | Re: Re-Lacquer after buffing ? |
Wipe it down with naptha and give it a light sanding prior to spraying again. |
Author: | WudWerkr [ Tue Mar 08, 2011 7:40 pm ] |
Thanks , Jim . I wll give that a try. As for the amount of laq you use per build ? how much do you spray on the average |
Author: | Chris Oliver [ Tue Mar 08, 2011 7:50 pm ] |
James... +1 on Jim's recommendation. And, it is not how much you put on... but how much you leave on. I know that doesn't help, but I heard a very famous mando builder say it once and had to chuckle. ![]() Good luck! Maybe a spirit varnish next time? ![]() |
Author: | WudWerkr [ Wed Mar 09, 2011 8:47 am ] |
Chris Oliver wrote: James... +1 on Jim's recommendation. And, it is not how much you put on... but how much you leave on. I know that doesn't help, but I heard a very famous mando builder say it once and had to chuckle. ![]() Good luck! Maybe a spirit varnish next time? ![]() ![]() ![]() ![]() ![]() ![]() |
